Rally Wheels
Old Apr 10, 2012 | 12:46 PM
bulldog's Avatar
Rally Wheels
I would like to take the centrelines off of my 67 Coronet, and put factory rally wheels on it. What do the factory wheels look like ? What should I be looking for ?
Old Apr 10, 2012 | 01:33 PM
Silverick's Avatar
Like these in a 14" x 5.5 or 6"....
Old Apr 10, 2012 | 05:07 PM
bulldog's Avatar
Do these also come as a steel wheel,with beauty rings and center caps ? There is a 1966 Plymouth Belvedere being advertised as a parts car here and it has steel wheels that look very similar to the Magnum 500 wheels except these aren't chrome but have beauty rings and caps.
Old Apr 10, 2012 | 06:30 PM
Go to Specialty Wheels and take a look at the Mopar section.
http://www.specialtywheel.com/wheel-showcase/mopar.html
Old Apr 12, 2012 | 02:21 PM
The later style 70's did have a trim ring
Old Apr 12, 2012 | 10:31 PM
Silverick's Avatar
Correct. '68 and earlier were chrome, '69 and newer had trim rings....
Old May 28, 2012 | 03:58 AM
bulldog's Avatar
So I've located a set of Magnum 500's. However they are from a 1973 Charger, will these bolt onto my 1967 Coronet,and give me the clearance that I need ??
Old Aug 1, 2012 | 05:59 PM
hangman's Avatar
Link you might want to dig into. Great customer service.
http://www.wheelsanything.com/
Old Aug 1, 2012 | 08:23 PM
You should be fine I had a set of the Chrome Magnum 500's on a 66 Coronet.
Best wheel ever made !!!!!! Clearance is tight on a 67 regardless of what wheel you use
65belair
Aug 24, 2015 02:24 PM
plum70
Nov 9, 2011 03:10 PM
edselehr
Oct 18, 2011 05:10 PM
BBQPIG
Aug 25, 2011 07:10 PM
mahd
Oct 27, 2009 11:39 AM
