What size tires can I fit
Old Mar 15, 2021 | 07:14 PM
Yellowjacket1972's Avatar
I have a 1972 charger with air shocks that I just got 17x7 inch rims for it what would be the best/biggest tires I could put on it. I would like to go as wide as would look good on the back but they are 17x7’s as well.
Old Mar 15, 2021 | 08:58 PM
I suspect you will be limited by the width of the 7" wheel and tire availability.
Old Mar 16, 2021 | 12:51 AM
Archer's Avatar
Yellowj -
Iowan is correct about the 7" wheel width being a limiting factor.
The air shocks are or can be a bit of a concern as well, for both tire diameter and width.
Air shocks can leak, and you have to consider clearance with the shocks fully deflated and expected spring travel.
I used to use air shocks a long time ago, as a poor man's way of suspension tuning, and it worked, but I used a 28" tire and it would pass a worst case scenario.
josehf34
Aug 13, 2014 05:53 AM
dougfunnie
Jul 23, 2013 09:14 AM
chiefgtx
Aug 28, 2009 02:44 PM
67 GTX
Aug 13, 2009 04:43 PM
fpereira23
Feb 9, 2009 09:04 PM
