1964 Dodge 440 Gas pedal lever broke
Hello,
My name is Kevin and I'm new to the forum. I was working with the new carb today and my gas pedal lever broke in half. Does anyone know where I can find a complete assembly? Also I live in Winnipeg, Manitoba, Canada. Looking forward to hearing from you, Kevin |
is that the one that goes through the floor? if the break is in a steel shaft a good braze or weld should do fine. if a straight shaft is broke you might split a tube around the shaft. just be careful welding.
