2006 dodge dakota steering problem
After replacing almost all suspension parts I still have play in the steering wheel.
New upper and lower ball joints steering shaft etc. Still have the sloppy play. Just 50000 miles on it. Started a 38K. Has close to an inch both ways. Also have a rattle in the column when I go over railroad tracks. Seems like there is some kind of adjustment or something to tighten this up??? I am sure it is in the shaft. I replaced the lower u joint shaft and it made little if any difference. Help Thanks David 1968 Sport Sattelite Conv 383 |
Steering gear my be no good...... Have someone turn the wheel back and forth, while you look at all the moving parts for slaup..
it has rack
Originally Posted by moparted
(Post 118508)
it has rack
Had to replace the steering box in my Ram at 45K miles because of slop. Do yourself a favor and put a genuine Mopar box in it, or do it twice like I did.
(Post 118508)
it has rack
2 Wheel Drive or is it a 4 Wheel Drive????
(Post 118511)
Oh...And those dont go out... Rite....
ReCheck the Rag Joint...... Also Wiggle the steering shaft to see if maybe the plastic shin went bad between the inner and outer shaft?
Just a note.... Some of those problems where covered under a Recall, you might call the dealer and give them your VIN # and see if your was one that needed to come in for the recall? |
Thanks for the info I will call the dealership. \
Where is that plastic shim located? How to I get at it? I know where the shaft goes down from the steering wheel. I do not see how I can get inside there if I have to. Any help would be appreciated. It is driving me to Drink. Thanks David |
Rack ! I would check the mounting rubbers
(Post 118508)
it has rack
So Mayfield once again you jump in with no response on what you think it is.. Or how to fix it... |
If it is a tilt wheel there are 3 E30 (male torx) screws that come loose and need to be tightened you do have to get into the steering column and you do need special tool to perform this procedure....Bill
Originally Posted by pro-tech
(Post 119296)
Really No sh!t,
So Mayfield once again you jump in with no response on what you think it is.. Or how to fix it... and it took you 3 weeks to respond. |
(Post 119322)
thanks for your help all of you. I still have the problem. I guess I have no tools to pull the steering column.
thanks I will have to do that. I am scared of dealorships but ......
