360 stall issue
my friend put a 360 into a 79 aspen and now we r having issues...it's just a stock truck 360 and has been torn down and put back together with all new rings bearings and seals it is topped with
a q jet carb and has a unregulated electric fuel pump(picked it up from orielly and claims it doesn't need a regulator) but now with the backround of the vehicle the issue is when you go to open it up
either from a launch or just picking up speed it will stall for a second then pick up again but other times it will just fall on it's face spit n spudder a bit then slowly come back
Sounds like a carb issue.
Why post so many...
times to ask that question? Are you typing this from a Blackberry?
Or just getting you post count up?
OK I'll stop. I just couldn't help myself.
not on a blackberry but on the instince..so i only get 200 char to post with....it sucks...
so i gatta ask cuz i just realized it...does it make a diff if it's a emisions motor not runnin the emmision stuff..got a block off plate on the egr spot and now tryin to come up with somthing for
the exhaust part...he's runnin a set of summit headers... and what do you sugest with the carb issue if it is one thinking too rich or lean?
we are kinda out of our playing field... we both are chevy guys this was his first car it had a /6 in it and well we tore it out about 5 years ago and this project sat way side while we have been
doing a ground up on a 84 monte carlo that turned into a drag car project...he's tryin to get more $ by getting this done and trying to sell it...
srry not a real good pic of it but there it is next to my stock 85 mc
