Mopar Forums (/forums/)
-   -   360 swap (https://moparforums.com/forums/f7/360-swap-101/)
thekinzuakid247 Feb 7, 2007 09:33 PM
360 swap
Does anyone know where i might be able to find swap mounts to go from a 225 slant six to a 360? Year One does carry them, but i was hoping i might be able to find them cheaper somewhere else.
Jonah Hex Feb 9, 2007 11:53 AM
Schumachers has /6 to small block conversion mounts. I am not sure if they are any cheaper than Year One, but you could look them up at http://www.engine-swaps.com
thekinzuakid247 Feb 18, 2007 04:04 PM
I looked those brackets up, and they do have them, and they are cheaper. Thank you very much, I appreciate it.
thekinzuakid247 Feb 19, 2007 03:00 PM
the 904 tranny on my slant six would'nt bolt up to a 318 or 360 would it?
Jonah Hex Feb 20, 2007 07:13 PM
In a word......no
The starter locations are different,and the bellhousing bolts won`t line up either. Whatcha sticking a small block into?
thekinzuakid247 Feb 21, 2007 04:13 PM
I have a 71 dart. i got it last july for $1000. it was inspected and needed nothing; ready to drive. Its not much, it's had alot of body work done to it, but the under side looks like its always been undercoated, so the unibody is pretty solid. it had 81,000 miles on it when i got it. it's not fast, but it's in pretty good shape for something that was an everyday driver for 35 years. like i said, it's no show car, but i'm only 20 years old, and i'm the only one my age i know of with a clasic car. and i've always wanted to restore a car since i was a little kid, i've loved cars eversince i was a toddler. Soooo anyway.....if anyone can give me any knowledge on this 360 or 318(havent bought an engine just yet)swap from what drive shaft, or yoke i might need, to what rear end will handle an 8cyl, to what's compatible and whats not in general, i would greatly appreciate it.
Thanks again,
Jared
thekinzuakid247 Feb 21, 2007 04:16 PM
Dart pics
here's a link to my pictures on my MySpace page if you're interested in seeing it: http://viewmorepics.myspace.com/inde...endID=61064681
Jonah Hex Feb 22, 2007 10:00 AM
Jared,
That is a pretty sweet looking ride for a grand! As far as bang for the buck, I'd go with the 360. It'll make more horses and more torque for less money than it would take to build a 318 to similar specs. You can buy a crate motor that puts out 390 horses and about 410 ft/lbs of torque for about 5 grand.
As far as trannys go, a 727 Torqueflite is the way to go if you want to stick with an automatic. They are pretty much bulletproof, when properly built. Of course, with that much torque you will want to go with an 8 3/4 inch rearend.
If you desire something a little tamer, you could go with a 360 rated at 320 horses, a 904 torqueflite, and an 8 1/4 inch rear end. The 8 1/4 is far easier to find and will be cheaper to boot.
joedirt77 Feb 25, 2007 04:13 PM
904 is plenty for a street driven small block. does your car have a 7 1/4 rear? if it does you should get an 8 1/4- there are lots of them available and gears, rebuild kits, trak loks, etc. are all made for this rear in the aftermarket. if you can get a 360 for the same coin as a 318, then i agree get the bigger cubes. you can build a stout 318 though so it doesn't have to be a 360. crate engines are pretty expensive, you can do better for less $.
