400 Engine Question
Ok guys, whats the low down on the 400 ci engine. What can I do to it and is it anything worth spending money on ?
Thx |
what do you want out of the motor? If its performance, I'd probably look around for a 383 or 440 instead. If its just to swap into a car to get moving and drive, then rebuild if it is needed and call it a day.
you can build the motor up to be quick
it still has decent size to it (400) |
It's A No Brainer....
The 440 is the way to go...
Polaradude, do you have a 400?
Like 78 says it all depends on what you want to do with it let us no k
Originally Posted by 67 GTX
(Post 10029)
Originally Posted by challenger
(Post 10032)
you can build it to be fast. do you already have a tranny and vehicle for it?
if you have an abody or light car they are the best wedge engines . they have the biggest bores short deck height so you can use lighter pistons & rods . which make them stronger & rev quicker , they use the same cranks as 383 so it's easy to get a budget forged crank . or you could use a forged 440 crank and turn down the mains . that is quite commen , all the common piston makers make pistons for that combo .( that makes a 451 cid ) if you have the money check out muscle motors or 44o source . com . yeah mate the 400 block is the way too go . all the best . dk
Originally Posted by deadkelly
(Post 10065)
Originally Posted by Polaradude
(Post 10068)
Thanks for the info deadkelly, cheers. Thanks for the reply Tim and Heather also. I found a 64 Polara in an old barn and it has the 400 already in it w/tranny and 8 3/4 rear. I'll post some pics shortly. Thanks again everyone, this site is great.
Even if you don't use the block save it a racer will pay you good dollars for it. If you really don't want it I probably would buy it off of you. MM |
