440 exhaust flange gaskets
Old Jun 25, 2011 | 10:57 AM
rickyr's Avatar
Does anyone know of a better than stock manifold to exhaust pipe gasket
for a 1968 440 HP
I have had my manifolds resurfaced and when I install the gaskets they last for a short time and start leaking again I wonder if there is an after market 2 bolt gasket that might last longer
Thanks
Old Jun 25, 2011 | 11:56 AM
John Van's Avatar
Rickyr, make sure both surfaces are flat and clean, and the way to go would be copper.But,I don't think anyone makes them,so buy some copper and make your own.
Try:http://basiccopper.com/samplerpacks.html
good luck,john
Old Jun 25, 2011 | 12:07 PM
rickyr's Avatar
I have made sure both are flat and clean
I will try copper
I have been just getting stock ones from AutoZone
Thanks
Old Jun 25, 2011 | 12:22 PM
Have you tried the local dealer for a gasket ??
Old Jun 25, 2011 | 03:40 PM
MercuryDon's Avatar
Are you still using a H pipe ? If not your pipes may be swaying and causing your problem.
Old Jun 26, 2011 | 05:39 AM
rickyr's Avatar
I do have the factory H pipe
I have not tried a dealer but I have tried AutoZone & Year One and both are the same
Thanks
pro-tech
26
May 30, 2014 05:45 PM
71mopar
Jan 7, 2014 08:14 PM
Mopargrandpa
Sep 9, 2012 10:25 AM
demonstrator
May 16, 2012 10:00 AM
Barfly
Apr 20, 2011 09:42 PM
