440 heads 383 heads?
Old Nov 18, 2009 | 10:16 PM
getsum's Avatar
will 383 heads fit on a 440? im rebuilding my 440 and the heads are cracked in all the exhaust seats. is this a common problem with these heads?
i have a spare 383 sitting around at a freinds house but i dont wanna rip it apart unless i no there ganna work.
thanks
Old Nov 19, 2009 | 03:15 AM
BuckNeccid's Avatar
They'll bolt right on. The valves may be a different size, or you may have different springs, but if you're just looking for interchangability, yep, grab em and put em on there.
Old Nov 19, 2009 | 01:58 PM
yes, they will fit
not sure about compression or power changes though
Old Nov 19, 2009 | 07:56 PM
getsum's Avatar
cool thanks i just wanna put them on untill i get the 440 ones fixed if they can be.
Old Nov 20, 2009 | 07:15 AM
BuckNeccid's Avatar
Unless the ones on your 440 are something like Max Wedge heads, odds are they aren't worth fixing, once you take cost into consideration. You can buy new, ready to bolt on, complete aluminum heads for right at $900 a set. See what your machine work would cost, then compare.
Old Nov 20, 2009 | 03:31 PM
deadkelly's Avatar
yeah just a clean & light lapp of the valves & new valve stem seals & you'll be right as rain . & like ol bucky said if your spending any where near $400 spend the extra $500 & get those 440 source steath heads , guys i know over here that have em are very happy .
Old Nov 21, 2009 | 08:37 PM
getsum's Avatar
i dont no what the stock heads are but they have the numbers 3769902 stamped on them. are they worth rebuilding? as for the machining i can nurle them and grind the valves and seats myself the only thing i need is to have valve seats put into them and im not sure yet if the machine shop can do it and how much it will cost if they can.
thanks, jason
Old Nov 21, 2009 | 09:08 PM
deadkelly's Avatar
they are 902 heads it's the last 3 numbers we go off . it will cost to much , & the valves aren't suited to unleaded fuel . & you will find the valve guides will need k-lining or replacing , a acid clean ect ect is it worth it . if you can't do it your self or have a buddy that will help you out i would definitely get the 440 source stealth heads . they flow much better, the same as eddlebrock rpm performer heads & have bigger new stainless under cut stem valves new guides , can handle up to a .600 th lift cam straight up . it would be bolt on 50 - 70 hp & if you added a mild cam 484 lift or there abouts you'd be looking at 400 + hp easy with a good tune 450 hp . if you only want a std replacement i'd still use them . it's a no brainer to me 902's are just old boat anchors . hey i still did up a pair of 906 heads & spent $1600 on them but that was just because i was stubborn & wanted to see how much power i could get out of them my self , I'm only using them to run my engine in & to flow them . but if i was you go the stealth heads for sure . get some get some how do you kill wemen & children ! easy just don't lead em so much
Old Nov 21, 2009 | 09:48 PM
theomahamoparguy's Avatar
the 902 heads are from the year 1974. They have the same ports as any of the 440's or 400's from 71 on. Not as good as the 68 to 70 906's, but darn close. They did come with hardened valve seats (exhausts). Would be a good head to rebuild if you were on a budget. they have an 88cc combustion chamber just like any bigblock from 68 on.
Old Nov 22, 2009 | 04:18 AM
BuckNeccid's Avatar
The worst thing I see with what you want to do is that you said all the exhaust ports have cracks. I think once they have the heads in place, and have to oven weld the cracks, then cut that down, then cut the seats, install hardened seats, maybe change valves, you're looking at a LOT of money. The cracks are NOT a good thing.
Old Nov 22, 2009 | 10:06 AM
KyleLR's Avatar
Junior Member
I have a set of heads for sale I took off my 440 I'm rebuilding. They're from 1975, the number stamped on the heads is 4006452. If your interested PM me.
Old Nov 22, 2009 | 05:51 PM
deadkelly's Avatar
i think a second hand working heads is the way 2 go for cheap . because as soon as you start pulling old heads down before you know it they need a full machine job + parts & when you weigh up what you get for $900 with stealth heads there is no comparison . thats all at leased have a look at them , you can use std rocker arms & head bolts they'll run cooler & ping less . i know I'm very one sided but it's the way 2 go for sure . my mate bought some for his 520 cid 440 stroker , i spent a bit more & bought Indy ez heads but i still had to do a pair of iron 906's just because . if your dead set on a tight budget have a look at these 452's they are genuine unleaded heads or have a go with your 902's just don't waste money on them thats all . if you do use the 902's back cut or grind the ski jump on the back of the valve head & bowl blend if you can . it is so easy it's not just for hp more for efficiency & broader torque curve . good luck
Old Nov 22, 2009 | 06:43 PM
KyleLR's Avatar
Junior Member
I have full rocker arm assembly also.
Old Dec 2, 2009 | 03:05 PM
getsum's Avatar
i got my 383 heads off and theres no cracks!! There 2406516-5 heads so that means there 516s right? i read on another tread that said there 73.5cc.
thanks
Old Dec 7, 2009 | 09:36 PM
getsum's Avatar
I found out that my comp. ratio will be around 11.5:1 does any one no what heads would get down to 10:1 or less or if theres anything i can do to these heads to make the chamber bigger or anyting, i dont wanna have to run race fuel.
thanks
Old Dec 7, 2009 | 10:07 PM
deadkelly's Avatar
thanks
sell them & get stealth heads . or 452's like ole mate above has . any of the open chamber types will do . i would look for a good set of 452's shop around . i still think the stealth heads for $899 are a bargin , they have 84 cc chambers & cast iron is junk ... you must be sick of me buy now ay .
Old Dec 8, 2009 | 02:21 PM
getsum's Avatar
where can i get the stealth heads and do you think 84cc would get my comp. down to about 10:1. i just dont wanna waist money i dont have on something im not ganna be happy with.
how may cc are the 452s?
Old Dec 10, 2009 | 10:01 AM
MrOldart2U's Avatar
I do believe its: http://www.440source.com
labradorian70
Sep 24, 2014 09:44 AM
dboykin
Oct 11, 2012 08:01 AM
LukeRacing
Mar 30, 2011 05:48 PM
mach3107
Feb 8, 2011 05:07 PM
1970Challenger
Oct 22, 2010 05:09 PM
