Mopar Forums (/forums/)
-   -   4bbl throttle linkage. (https://moparforums.com/forums/f7/4bbl-throttle-linkage-2681/)
craveman Apr 2, 2009 10:14 AM
does anybody have a pic of a 4bbl throttle linkage. im converting my old 2bbl and i cant find any 4bbl mopars around here anywhere and i dont know which part i need. I know i have to make the kickdown linkage longer which i can do with some couplers and threaded rod.
69Fury3 Apr 3, 2009 01:28 PM
Why don't you just get a new kickdown cable (like $70 from Summit) instead of messing with lengthening your current kickdown?
craveman Apr 3, 2009 01:31 PM
actually i found out my stock bracket would work on this carb. i made my kickdown cable for 3 bucks and it looks pretty good. i have to cut a hole in my hood to fit the air cleaner on though.
69Fury3 Apr 3, 2009 01:36 PM
Maybe use one of the ultra low profile foam Edelbrock air cleaners (EDL-1002)
67 GTX Apr 3, 2009 02:39 PM
is this car your daily driver?
why cut the hood?
craveman Apr 3, 2009 05:49 PM
yeah
craveman Apr 3, 2009 05:50 PM
cause then i can put in a cowl. i have another hood for when i eventually put in a 4bbl that doesn't sit so high
67 GTX Apr 3, 2009 06:51 PM
oh, ok
i'm just worried about when it rains
craveman Apr 3, 2009 08:55 PM
if i put in a cowl it should be fine. im gonna put a lip around the base of the rear opening so water doesnt run into the hole
67 GTX Apr 4, 2009 09:32 AM
good idea
