5.7 Hemi Swap Tech question
I put a 5.7 hemi in my 68 dodge dart and Im having some problems with the engine. It will not fire the injectors while it is cranking. If I give it a shot of ether it will pop off and then the injectors start to fire. I have power to the injectors, the computer just isnt grounding them out when they are suppose to fire. Ive tried to trick the computer into thinking it was running and still no injectors. Is anyone familar with the 5.7 wiring or has a clue what would cause this?
I'd ask on Http://www.bigblockdart.com
Theres alot of guys over there I know who have 5.7 and 6.1 hemis in their cars.
I'm Sean
I have a 2014 5.7 hemi 1500 express
and then I have a 2002 dodge ram 1500 4.7L next Gen v8
there both 4x4 as well so my question is ifI took the front clip off and the cab off and the bed off of the 02 would it go onto the 2014 frame and would front clip and bed also go onto the 14 with no problems other than the dashboard and cab harness would have to be changed out as well but would I have any issues with that or is there anything I should be aware of with that type of conversion ?
totallychris30
Mar 2, 2018 06:42 AM
fcpnative
Sep 1, 2010 08:48 PM
