'71 318 Engine vs. '85 318 Engine
Guest
Posts: n/a
what is the engine serial number?
might i suggest this >=)
if you have enough room under the hood
http://www.theautochannel.com/autopa...nlk_559oy.html
Guest
Posts: n/a
assuming you are thinking of purchasing it still and havent made a decision, It SHOULD bolt up. BUT... I think I read somewhere about some of the later 318 engines being externally balanced instead of the olders which were internally. that may be something to look into.
