727 transmission
hi i have a 70 belvedere and my transmission is going i was going to put a 727 transmission torqueflite from a 85 dodge ram. will it just bolt in or am i going to have to cut the drive shaft and k member ? also i plan on putting a 340 in the car he says it will bolt up to a 5.9 or a 5.2l. the 340 is a 5.6 will this also be a problem?
Who said that it will bolt right up?
What engine do you have in there now, and what size is the engine in the ram? |
the guy selling the transmission i dont know what type of engine the ram had. i have a 318 right now
"727 torqueflite tranny rebuilt w/all B&M parts . Has all B&M internals as well as shift kit .Kevlar bands and B&M torque converter (slightly higher stall than stock for higher torque)Excellent for on the fly shifting .Only has about 3000 miles since rebuild.Tranny will fit any small block mopar motor(5.9 or 5.2) .Came out of a 1980 Ramcharger ,was then in 1985 W-250.It is out of truck and taking up space in my garage.Also have flex plate required for 360(5.9 litre) motor hook up (internal balanced) "
this is what the ad said |
From that I would say you would be able to hook it right up to your current engine, but I am not sure about the 340. I assume someone has an answer for you on the forums.
