75 dart ????'s
Old Mar 14, 2008 | 01:28 PM
If I was going to build a "budjet" street engine, a 360 would be it.
318's are too hard to deal with without major issues, unless you have a lot of junk parts and need to buy pistons anyhow, because the 360 heads will drop the compression. 318's are limited for CID
Much easier to get more street torque out of a 360
340's are too rare and expensive.
360's are externally balanced, and you'll have to have a properly balanced converter or flex plate, or flywheel.
360 oil pans are unique, so you'll have to find one to fit, or "make" one. I have done this---cut the rear seal area out of an unwanted 360 pan, and morped that piece into a 318/340 pan
trev0006
Jun 12, 2013 04:31 PM
