77 Tradesman steering column help
Hi all, I removed my steering column as part of my resto. I've fixed the shifter arm, stripped it all back for respray etc. I need to know if there is some kind of bearing or bush at the steering gear end that separates the steering rod from the shift tube? It looks to me, from looking round the web, that some Mopar cars have like a nylon top hat set up, is this the same for B200's, if so do any of you clever folk happen to know the part number - I can have one made if you do?
Thank you in advance for any info Timbo ;) |
Wow, its been so long since I've gotten into a steering column that far I can't remember a thing and I don't have a manual for trucks. I'll look around for diagrams and hopefully someone else here can help.
is this what you are talking about? https://www.ebay.com/itm/NOS-Factory-OEM-Mopar-Steering-Column-Gearshift-Tube-3496285-1972-1978/401121971399?fits=Model%3AB200+Van%7CMake%3ADodge& hash=item5d64bb8cc7:g:BokAAOSwUEVYDA4P between this and the steering shaft? |
(Post 146622)
Thanks Lowan |
(Post 146622)
is this what you are talking about? https://www.ebay.com/itm/NOS-Factory...kAAOSwUEVYDA4P between this and the steering shaft? |
