79 dodge aspen 318 w/ constant backfire
Hi im a rookie at this and this was my first rebuild. Well i rebuilt my 318 and have i back together but it is constantly backfiring, iv messed w/ the carb, cleaned all plugs, checked the wires, and there is no leaks in the exhaust. It starts to pop when under pressure and when idling it also will die when left too long.
Your help will be really appreciated. Thanks |
i have a 318 with basicly NO exhaust, and it doesnt backfire. Wires all older than... well probably older than me...
First, define what you mean by backfireing
Does it pop back through the carb, or crackle and pop out the exhaust when you "let off" the throttle? I'm assuming it pops back Under what conditions does it do this? alll the time? when cruising? when under power? when under heavy power? at high rpm, medium, all ranges? A rythmatic popping, like a dead cylinder, can be caused by a flat cam load on an exhaust valve, and of course sticking valves, broken springs, burned valves, etc (Run a compression check) Are you ABSOLUTELY sure that the plug wires are in the right order? (Very easy to switch 7-8- The plug wires are good? Check them with an ohmeter Is the distributer cap new, clean, and dry? Pull the cap and look for "carbon tracks" between two connections Can you get a smooth idle? Do the idle mixture screws have a noticeable effect? Try this: Get a small screwdriver, or a test light. Ground the screwdriver with a wire/ clip lead to the block. Pull the boots loose off the distributor cap. With the engine at the smoothest idle you can get, short out the spark at each cap tower one at a time. Watch a tach if possible. EACH CYLINDER should drop the idle about the same amount of RPM, and the engine should "sound" about the same on each. CONGRATULATIONS!! You've just performed a "cylinder balance test" with no special equipment. If any one or two cylinders doesn't "drop" the same amount, it indicates a problem in that cylinder If two cylinders that are physically adjacent on the block are weak, you might have a head gasket leak between those two cylinders How did the plugs look, any evidence of something like antifreeze leaking into the cylinder? |
It goes out the exhaust and I know there is some popping from not having pipes out the back but thats not all. It pops some when in idle and it has that rhythmic pop when accelerating. Normally its really pretty quite but when it accelerates and I let off the gas it'll really backfire load. But what really bothers me is when I let of the gas and let it idle it will die pretty fast.
A rythmic pop sounds more like a weak cylinder. Read my post, take a compression test, and try the cylinder balance test.
You may have more than one problem, namely something in the idle circuit of the carb. Do the idle screws have good effect? |
Its possible the idle could be off on the carb, i am going to try those tests. Thanks
Check your timing, maybe you set your timing chain off 1-2 teeth when rebuilding, very easy mistake
Does it sound a bit like this?
