Mopar Forums (/forums/)
-   -   85 RAMCHARGER (https://moparforums.com/forums/f7/85-ramcharger-4921/)
LAUNCHPAD01 Dec 18, 2009 02:52 PM
85 RAMCHARGER
I HAVE A 85 RAMCHARGER WITH A 318 THE PROBLEM IS WHEN IT GET WARMED UP I LOSE SPARK. I'VE REPLACED THE DISTRIBUTOR AND COIL AND BRAIN. WHAT CAN BE THE CURE ALL. THANKS FOR THE HELP.
blue 68 gts Dec 18, 2009 04:57 PM
Try measuring the resistance in the plug wires and see if they are within spec...
Try new plugs?
78D200 Dec 19, 2009 03:15 AM
Do these still run the ballast resister?
LAUNCHPAD01 Dec 19, 2009 05:25 AM
I'VE REPLACED THE BALLIST ,PLUGS ,WIRES,CAP AND ROTOR. I HAVE NO CLUE AS WHAT TO DO NEXT.
karkrazy Dec 19, 2009 09:30 AM
No Juice
Try the voltage regulator...just a shot!
blue 68 gts Dec 19, 2009 11:58 AM
Ignition switch
