adjustable rockers question
Old Feb 24, 2012 | 08:41 PM
michuy's Avatar
what is the procedure for adjusting adjustable rocker?
Old Feb 25, 2012 | 09:34 AM
Hydraulic lifters or solid lifters?
Old Feb 25, 2012 | 06:17 PM
michuy's Avatar
adjustable rocker ?
Hydraulic lifters. Compression checks out within 10%, and the valves aren't making rattling noises or anything like that. Everthing sounds tight, almost a to tight feel to it in fact if I can describe it that way. The motor does have a "mild cam" I was told, and it does have a slight lope to the idle. The problem is that it has a "surge" whether accelerating or just holding the throthel open. Carburetor/fuel pump/filter all check out ok. So I keep coming back to the adjustable rockers, or maybe the rockers/cam combination?
wma1950
Apr 17, 2014 09:36 AM
69POLARA383
Jun 26, 2012 05:31 PM
Cudaparts
Oct 24, 2011 09:27 AM
moparjohnson123456
Jun 14, 2011 01:28 PM
Commando
Jan 7, 2009 07:20 AM
