Mopar Forums (/forums/)
-   -   Aluminum Radiator vs. Factory (https://moparforums.com/forums/f7/aluminum-radiator-vs-factory-2661/)
plymouthrr1985 Mar 31, 2009 07:22 AM
I was thinking of running an aluminum radiator on my 69 rr. Has anyone used these and what are the pros and cons of each??
Polaradude Mar 31, 2009 07:31 AM
Aluminum is lighter, better cooling with the right fan/shroud set up, usually more volume and way better flow. I really don't know any cons, in my opinion it's the way to go.
67 GTX Mar 31, 2009 04:39 PM
if you dont car about the stock look, aluminum is better
plymouthrr1985 Mar 31, 2009 05:14 PM
What companies make good aluminum rads?? I know Mancini Racing offers custom built ones for like 500 bucks
Commando Mar 31, 2009 07:55 PM
Be Cool makes them as well, not sure on their price range though.
78D200 Apr 1, 2009 03:29 AM
If you go with an alum radiator, you might want to install a hig flow water pump to get the most out of that radiator then.
