A/C delete pulley for '69 - 383
Does anyone know where I can find an AC delete pulley for my '69 383 ? And how does it look like ? Can I use the original belts again ? I want to remove all the AC parts ; 1. I don't need it in my country 2. The (original) compressor is damaged/blocked inside. Thanks |
Thanks,
I contacted them earlier today. This is what they answered me : "We are closed till january 2nd. But to do your engine correctly, you will need the following 1-BPE4012 Crank Pulley 2-BPE4014 water Pump Pulley 3-BPE5250 Alternator mounting bracket , with bolts and spacers Kit 4-BPW4020 Single Groove alternator pulley" This is quit a lot. I tought that there was someting (pulley on bracket) to mount where the AC was and that I could use the same belts ? |
Hey they know their stuff so I guess you may need all that they listed.
Mancini has pulley kits too
| All times are GMT -7. The time now is 02:57 AM. |
