cam lift?
ok
jack the back of the car up
put the car in neutral
mark the bottom of the rear tire
and mark a spot on the driveshaft
use chalk
make one revolution with the tire, and see how many times the drive shaft makes a complete revolution
that will give you your ratio
by the way, do you have sotck rims and tires?
if not, you wont get a reading that was original to the car, but it is ok
use chalk
deadkelly
03-13-2010 06:27 PM
