Carb/Trans Kickdown Cable Bracket 727 Help
I got a 87 360 with 727 trans and it has the factory quadrajet carb and i put a new cable kickdown on it.
I got it working temp right now but do they sell a Cable Bracket Corrector for this carb to hook this cable to?? I can't seem to find anything for this aplication. |
It should hook up to the same bracket as the throttle cable and then to a stud on the carb..
I believe that would then be pushing the cable towards the firewall.
I need it pulling the cable towards the front engine. |
Never mind that what i said i knmow what you mean but ill probably have to get the lokar bracket and throttle cable to make it work.
| All times are GMT -7. The time now is 02:29 AM. |
