Definition of "cam wiping"
Old Nov 4, 2008 | 03:02 PM
Erikthegoalie's Avatar
Member
As a 23 year old aspiring mechanic who only really knows late model LSx motors, I have never heard this term before until recently when I began tearing down my Dad's 440. Does it have something to do with flat tappet style lifters? Since I have only had experience with roller cams and lifters, I was thinking this was a possibilty.
What is the technical definition of "wiping a cam?"
(sorry for dumb questions)
Thanks!
Erik
Old Nov 4, 2008 | 07:52 PM
ok, this ties back to my zinc problem
when the lifters destroy themselves, the next thing to go is the cam. the bottom of the lifters gets rounded, until it finally opens up, losing oil pressure. at least point, there is no question that the cam will be destroyed too, (wiping out the cam).
Old Nov 4, 2008 | 10:09 PM
Member
Ok, I see, so its "wiping out" the cam....like f'n it up?
THANKS brother!
E
Old Nov 11, 2008 | 06:25 PM
challenger's Avatar
as i have stated in recent post the vr1 valvoline oil has one of the most ppm of zinc but if you are in a cold weather state and you plan on driving it while its cold out you should run the maxlife oil as it has thinner grades , i have always used valvoline oil in my rides and did try the full synthetic oil in my challenger this past summer and it was a mistake as it only has 850 ppm of zinc , but the maxlife is a good choice for the cold months and the vr1 is the best in my book for the summer but i am sure there are more oils out there that carry the same ppm's as valvoline but my choice is just that , hope this helps you out alittle bit further
Old Nov 11, 2008 | 07:06 PM
i run rotella T
i think it only has 800, but i was assured that would be enough, and ive driven a lot since the rebuild i did, and its running fine
Old Nov 12, 2008 | 05:11 AM
Member
GREAT INFO guys, thanks so much!!!
Erik
Old Nov 12, 2008 | 02:06 PM
no problem
good luck
mystarcollectorcar.com
Apr 16, 2010 03:42 AM
transman037
Jan 20, 2008 09:56 AM
BB1
Dec 9, 2007 11:36 AM
rafilskis
Sep 4, 2007 01:57 PM
