Mopar Forums (/forums/)
-   -   Distributor leaking oil (https://moparforums.com/forums/f7/distributor-leaking-oil-7874/)
ChargerBoy'71 Oct 27, 2010 02:08 PM
Hey guys,
I pulled my distributor to clean it and ever since, it has been leaking oil to a point where it pours onto the exhaust manifold. I'm thinking its just a gasket, but are there any other possible causes?
blue 68 gts Oct 27, 2010 04:04 PM
If you're sure its coming from the Distributor, then its just the O-ring
ChargerBoy'71 Oct 27, 2010 04:37 PM
ok thanks
scotts74birds Oct 27, 2010 05:11 PM
You are losing timing fluid. Loose too much, and you may become retarded!:D
blue 68 gts Oct 27, 2010 05:39 PM
I was going to say bad stuff, then I saw your name next to your post. LOL :D
ChargerBoy'71 Oct 27, 2010 06:07 PM
so its the gasket or the O-ring?
rr69half6bbl Oct 27, 2010 07:05 PM
lmao, youll have to excuse scotty, hes just being scotty, actually you need both. the o-ring fits in a grooved slot under the bottom lp of the dist. then there a paper gasket that fits under the dist base when you put it down.
67 GTX Oct 28, 2010 01:48 PM
are you a big block?
if i remember correctly, there is no extra gasket, just the o-ring that is on the distributor
either that is bad, or your PCV and breathers are clogged, so the high pressure in the engine is forcing the oil out of the distributor, or the bushings in the distributor are worn out, and the o-ring cant hold back all the oil that is making its way up to it
ChargerBoy'71 Oct 28, 2010 04:10 PM
small block. i re-timed the engine when i replaced the intake, but i dont remember any mounting gasket. Thats most likely the problem.
rr69half6bbl Oct 28, 2010 05:52 PM
teh gasket just sits undr the dist. base. its a secondary sealfor it and sets between the block and dist. where as the o-ring seals in the block ,not on top.
