Mopar Forums (/forums/)
-   -   Distributor question... (https://moparforums.com/forums/f7/distributor-question-9033/)
jjm Mar 21, 2011 07:11 PM
I am rebuilding a 440 for my 70 RR and would like to get some thoughts on a good distributor set up for it. It will probably be around 450 to 500 hp and will have a six-pack and 4-speed.
thanks JJM
blue 68 gts Mar 21, 2011 09:37 PM
I have just an EI Distributor and Orange EI Chrysler box..
The Distributor is a $50 ish one from Schucks (O'reillys).
11's all day long with no problems.
Gorts 5th May 29, 2012 01:26 PM
any thing but a pertonix tryed it 4 bad ones went back to tried and true we use mallory i like the electronic my bro uses unilite wat ever u use make sure u use recommended coils and ballasts
Coronet 500 May 29, 2012 02:42 PM
What ever type of control I would spend a little more for a billet housing and check what bearings they use and an easily adjustable mechanical advance mechanism. You really can't go wrong with an MSD as they have very good technical support.
