dodge magnum motor questions
hey there i got a question for ya all . i got a 1993 dodge 360 the cylinder heads are still the shaft mounted rockers. it has a cast crank and dished pistons. i checked the compression is about 8.5 to 1. so with a stock bottom end how much horsepower can this combo handle? i wanted to build this setup to about 425HP can this rotation assembly take this?
thanks all |
No turbo, super charger or nitrious and you should be all set. I might look into a forged crank though.
If your gonna chang out the crank you might as well put a stoker kit in it.
ok, thanks for the info.! i want to leave the bottom end stock. how far do you think i could spin the stock rotation assembly to. i wanted to get 5,500 to 6,000.
I think (99% sure) I read they could operated up to 6,500 RPM stock.
