Mopar Forums (/forums/)
-   -   double single or none stud starter fastner (https://moparforums.com/forums/f7/double-single-none-stud-starter-fastner-5685/)
OHD Mar 24, 2010 12:26 PM
When you guys rebuild a belhousing do you double stud, single stud top or bottom, or just nut and bolt for the starter attachment?
I have found that 675-033 Dorman studs work well both top and bottom or you can weld 675-010 on the NC side at .500 to bottom out and work fine. Also Fastenal 22870 bolts, work great.
I use Nippon Denso mini starters for everything I put together.
scotts74birds Mar 24, 2010 02:33 PM
I try not to use a stud for that application. Sometimes there isnt room to slide something off a stud.
SPICOLIE203 Mar 24, 2010 03:43 PM
I think a stud on the bottom is stock, but if you have headers it for sure would be easier to have two bolts instead of a stud for fitment reasons.
toad490 Apr 14, 2010 04:39 PM
http://www.classicmoparforum.com/dou...arter-fastner/
