Evans Engine / Radiator Coolant
Old Jun 8, 2015 | 02:45 PM
Magoo's Avatar
Question Evans Engine / Radiator Coolant
I purchased a car and not knowing that it had 100% Evans in the cooling system, I added approx. a quart of 50 -50 water and anti-freeze. - According to Evans literature this is a No - No. - I called Evans Tech and asked if this would lessen the effectiveness of Evans coolant. I was only looking for ballpark info. The tech person would not tell me, instead she said "take a sample and send it to us". -- This stuff cost close to $50/gal, incl shipping. Obviously, I don't want to spend $200 to re-fill the system. -- Does anyone have info and/or comments regarding this ? -- Thanks
Old Jun 8, 2015 | 07:25 PM
Archer's Avatar
Magoo -
I've seen the ads for Evans, and my gut reaction is add all the water you want.
If you have cooling issues, look elsewhere - ie - find the real cause.
If you're sold on the hype, then yes, odds are you will have to do the full purge procedure.
Old Jun 9, 2015 | 03:39 AM
Magoo's Avatar
Originally Posted by Archer
Magoo -
Thanks -- I agree. - If the motor gets hot, and If their Hype is true, then with a 14lb cap, the 50-50 would boil off around 240 degrees, and leave the Evans. -- The motor is a Mopar 360 / 408 in a 69 Valiant Post Car. -- A fun street ride.
Old Jun 9, 2015 | 05:42 AM
Archer's Avatar
Magoo -
If you engine reaches 240*, you might have bigger problems the the coolant.
That's the problem with the theory. Their stuff may have a higher boil-off point, but the engine still isn't going to be happy with those temps.
Old Jun 9, 2015 | 05:53 AM
Magoo's Avatar
Magoo -
I agree. - I don't plan on that happening. - It runs real cool - never over 200. - Thanks
hckrphil
Jun 17, 2014 09:53 AM
BruceB
Aug 28, 2013 06:24 AM
gotdust
Jul 9, 2010 03:23 PM
MarkyMark12345
Jan 31, 2010 09:30 AM
64fury
Sep 5, 2008 06:32 AM
