Mopar Forums (/forums/)
-   -   exhaust (https://moparforums.com/forums/f7/exhaust-9109/)
Drakovich Mar 31, 2011 10:10 AM
exhaust
I have a 318 with dual exhaust and the passenger side exhaust kind of makes a chattering noise near to the engine or there about, only thing i can think it to be is a loose bolt or several but I'm wondering if there's a torque spec i can check them for or if it could be something else? the exhaust is also rusty so i know its old but i cant afford to replace it at this time.
440roadrunner Mar 31, 2011 10:58 AM
Might be the heat riser?
Silverick Mar 31, 2011 09:13 PM
Yes, it is the heat riser in the passenger side exhaust manifold. It is normal.
lunati318 Apr 3, 2011 07:29 PM
IF the manifold does have a heat riser it could be it. But, the bolts going from the manifold to the head should just be good and tight man. no real need to torque
