fuel pressure problems
I recently put a carbureted engine into a fuel injected car but did not replace the fuel pump . anyone know where i can get a fuel pressure regulator that will control the fuel pump. The fuel pump runs all the time and floods the engine. My carb can only take 4 to 6 psi and the pump runs 8 to 10 psi. Its a in tank fuel pump and I already by passed the ECM and ran a new relay and fuse so if I had a fuel psi regulator I would be set.
I found alot of them here on e-bay (universal with gauge.) price Range from $15.00-$150.00...hope that's what you where looking for?
http://motors.shop.ebay.com/i.html?_...egulator+dodge |
you can also try summit racing
i like em for the return policy in case i want to try a different combo wat type of car is this in |
We use a Holley 12-803BP with the bypass back to the tank on the 92 truck. Works well and keeps the fuel temp down.
