fuel problem on 318 2 barrell..
here is the situation. to start my car i have to put a little gas in the carb. when it starts it purrs like a kitten. then 15 or 20 seconds later it just shuts off. for one i am not sure of the vac. set-up for this carb. and a guy at work told me that i have a hole in my fuel line somewere. personally i have no idea. so i am turning to you guys. any ideas? thanks gus.
What is the car?
Couple things for you to look at: Make sure that you are getting fuel to the carb. Pull the line after the pump and turn the car over and see of gas come out (put a can or something st the end to catch the fuel). If it comes out then you could have a clogged filter between the pump and carb. Follow the fuel line from the tank to the engine looking for leaks. Make sure you have gas in the tank, you can't always trust the gas gauge (I learned that the hard way). With the lines all hooked up, remove the air cleaner and see if gas squirts out of the jets when you open the throttle. These are just some things that you can look at first. Let us know what you find and we will try to help you out some more. |
Ya what Tim said, but I have one question, when the car is running can you smell gas coming from anywhere?
Actually, if you turn it over for about 15 seconds, that would be more than enough time for a leak to be seen, as long as the pump is working. If the pump is working then you would be able to see gas on the ground around where it is leaking from.
Exactly
cool. my car is a 67 coronet 500. i checked the filter yesterday and it was fine. today i plan to look for leaks. and if it runs fine for that short time the pump should be fine right? thanks guys.
Maybe. Disconnect the fuel line after the pump and turn the motor over while the line is run into a milk jug or something to catch the fluid. If the pump is working, then you should see fuel in the jug. If there is no fuel, then either the pump is bad, you have a leak that the pump can not overcome (that would have to be a pretty big leak), or there is a clog in the line before the pump.
Where is the fuel filter, is it before the pump? Could be in backwards or clogged.
The filter should be after the pump. There should be one either in the tank ot between the tank and pump as well, but not always.
If you can't see/smell gas you may have a float sticking or a sunk float, ie: hole in it, check float and just give the side of the carb a gentle rap with a tapometer or check for our old friend the vacuum leak.
thanks for all of the info. yesterday i got under it and found that someone had replaced a section of fuel line spliceing the ends togeter with rubber hose. on one section of rubber hose there was no clamps on the hose. i could see were fuel had went out the front and the back . i put 2 clamps on it but i still had to prime the carb to start it. but once it started it ran fine enough to take for a spin. under load though it was backfireing alot so now i think i need to do some timeing games. one day i will be driveing. the thing stopped on a dime though. i went through the entire brake system 2 months abo. thanks guys. anymore advice is welcomed.
The backfiring is a timing issue. Also go through carefully and make sure that each spark plug wire is on the cap in the right order and going to the right cylinder. I know that if you coss 4 and 7 ( i think) the motor will still run but not well. After you have made sure the wires are in the proper order, go ahead and mess with the timing. You may also need to adjust the mixture screws on the carb as well, but get th timing to where it should be first and go from there.
Glad to hear that its running for ya and stops on a dime. :D |
| All times are GMT -7. The time now is 05:28 AM. |
