fuel pump priming?
How much turning of the engine has to occur for the fuel pump to prime itself and fill the carb? and allow the engine to run?
I had it running for about 5 mins by just spray bottling fuel in the carb.. would that be sufficient time? the pump is going to turn anytime the engine is right? Maybe i have to add new lines and an electric pump tank-carb..? |
If you have a mechanical pump now and the lines, filter etc are good and the pump itself is good it should deliver fuel right away.
If you had it running for 5 minutes by misting/spraying fuel into carb yes the pump should of 'picked up' the fuel. Only thing it can be no fuel in tank, or bad pump. If there is a pre-pump filter it could also be plugged....;)
the fuel pump only needs a few seconds to really prime itself
i would check over your fuel lines, change gas filter and check your timing it could be so off that the car just wont start |
| All times are GMT -7. The time now is 02:59 AM. |
