Harmonic Balancer for 440
Old Dec 17, 2008 | 06:44 PM
Commando's Avatar
I am trying to figure out if I need to replace the stock harmonic balancer from the 77 440, with a new one, as I replaced the crank with a steel one that is internally balanced. I believe the old one was externally balanced.
Old Dec 17, 2008 | 07:06 PM
Commando's Avatar
I am going to assume yes, but I am not sure if it is stamped for cast cranks only.
Old Dec 18, 2008 | 12:36 AM
rr69half6bbl's Avatar
yes, youll need a new balancer, 1 for a steel crank is only about an inch thick, where the cast 1 is 4inches thick and is marked cast crank only. a balancer from a 383 will work. they are the same. alot more 383 motors still in the junk yards.
alex_dodge1977
Aug 14, 2013 03:21 PM
440RR1973
Oct 23, 2011 12:44 PM
1966DartConvertible
Jan 14, 2011 08:49 AM
tracktor312
Nov 19, 2010 05:50 PM
jar84203
Oct 2, 2009 05:17 PM
