Help w/ Flywheels!!
Old 06-22-2010 | 11:23 PM
killer70cuda's Avatar
Junior Member
Help w/ Flywheels!!
Im not the most tech savy persone in the world so here I am.
I am running a 440 with 10.5:1 compression and im looking for a 0/neutral balance flywheel.
- 130 or 143 tooth?
- does the answer to the above question change if I want to run a Hydraulic clutch
-what size clutch should I run with either 130 or 143 tooth flywheel?
-im guessing that all of this will also determine the size of the pressure plate and such too.....
Anybody have any good setups or combos they would like to share that they are currently running?
I would really like to run a Keisler 5 spd in it some day, not sure if that will make it any easier answering my beginner questions. thanks so much for any input!!!!
-Brian
Fjant
13
12-16-2011 09:26 AM
BMD 68' Dart
03-30-2009 11:10 AM
Quick Reply: Help w/ Flywheels!!
