Mopar Forums (/forums/)
-   -   i think my engines about to die. (https://moparforums.com/forums/f7/i-think-my-engines-about-die-3736/)
carlosg7915 Jul 29, 2009 10:04 AM
oil: check new air filter: check. i turn my car on and it doesnt stay on. it sputters, i need to really give it gas to keep it runnin. a lot of smoke. light smoke not dark. eventually after it warms up its fine though:confused: could it be my engine? carb? it was running perfectly days ago. no problems at all
78D200 Jul 29, 2009 10:06 AM
could be a loose connection between the seat and the steering wheel.
have you checked your coolant? compression check? did you adjust anything at all?
Polaradude Jul 29, 2009 10:09 AM
x2 on what Tim wants you to check.
carlosg7915 Jul 29, 2009 10:13 AM
what do you mean between the seat and the steering wheel? yes coolant is fine. How do i check compression/? i have a leaky power steering line. so i added a little bit they day before it started happening.
carlosg7915 Jul 29, 2009 10:14 AM
could my leaky power steering line have got something wet?
78D200 Jul 29, 2009 11:24 AM
What is the only thing that connects the seat and the steeing wheel together?
You'll need a compression gauge (can get one at any decent parts/automotive tool store). I pull the wire off the coil as you do not want spark and or fuel while doing this. Pull out one plug and thread in teh hose for the gauge. crank the motor over about 4-5 times. record what the gauge is reading. You want only a 10% difference between all the cylinders and about 90-120 PSI of compression. (a manual is great help for this).
78D200 Jul 29, 2009 11:25 AM
maybe some wires but thats about it. I don't think it is the problem, although you should fix it.
carlosg7915 Jul 29, 2009 02:04 PM
i filled up my car with gas about two weeks ago.it finally got low so decided to fill it up again today, when i notice i didnt have the gas cap on. I must have left it at the gas station two weeks ago. could that be it? (compression)// i bought a new cap, changed the gas to a higher premiumand took it for a ride. the engine didnt even make a peep. normally i hear a bunch of pings when i step on it.
ryan_e Jul 29, 2009 03:53 PM
the pings could of been detonation in which case you did a good job on gettin a higher octane
67 GTX Jul 29, 2009 03:56 PM
ya
the higher octane stoped the pings
did the engine feel better?
carlosg7915 Jul 29, 2009 04:12 PM
wayyy better... expecially the top end.
carlosg7915 Jul 29, 2009 04:13 PM
but im still not sure if this was the problem. my mechanic skills are not that great, im just learning as i go.
78D200 Jul 29, 2009 04:26 PM
Told ya it was a loose connection. lol
64fury Jul 30, 2009 06:22 AM
You don't live in a place where the kids are known for putting sugar in the tank? Could also be dirty gas, water in the fuel?
carlosg7915 Jul 30, 2009 08:49 AM
not around here... it now the next day so im gunna go check to see if it fixed the problem. (cross my fingers)
67Polara Jul 30, 2009 07:36 PM
so what i got from this is if i put like 97 grade gas in my car it will stop all the sqeaking and pings i hear when i floor it ?
ryan_e Jul 31, 2009 01:52 PM
maybe but what you need to do is figure out your compression ratio and then use the octane that can handle it, i think its up to 9.5:1 is 87 then 11:1 is 91 and 12.5 is the highest you can run pump gas, im not positive on these numbers though but its close
scotts74birds Jul 31, 2009 02:26 PM
I've found that the correct timing at wot is a balancing act between the dizzy and the proper jetting of the carb. This is NOT the PROPER way, but how I always did it was to mash the gas and advance the timing 2 deg at a time till it pinged. Then back off 2-3 degs. Pretty shadetree but I didnt care about the specs, I just set it to what the motor liked. I'm sure I'll get called out on this, but this is my personal experience, this is not meant to be advice.
67 GTX Jul 31, 2009 03:58 PM
with carb. cars, the highest octane you can run, (With iron heads) without pinging is around 10.5-1 if you are lucky
blue 68 gts Aug 30, 2010 08:19 PM
I know this is an old post BUT.... you're supposed to pull all the plugs out before doing a compression test
D100Guy Sep 1, 2010 10:27 AM
i can see this is going to be a rough crowd....lol
