intake problem
Anyone else here running a weiand action plus intake on their 318 or 360? do you have a problem with it sitting on the block? I got mine all bolted in and went to put coolant in and next thing I know I've got coolant pissing out of the driver's side front intake gasket area.
are there guide pins sticking up in the heads or the front or rear rails on the engine?
Did you put any RTV around the coolant ports ? .... do you know the history on the intake?
Originally Posted by richinny
(Post 4787)
Originally Posted by Doc
(Post 4792)
Do you know the history on the heads ? .....
i'll defer to doc, lol. if the heads are milled, does the intake have to be milled to match the angles?
(Post 4931)
The heads were replaced with the block as a long block assembly but a local engine shop about 6-7 years ago. they have not been milled. |
(Post 4933)
THIS was my point in asking you about the history of the heads ... it sound like you have a mis-match here. Try some RTV around the coolant passages and if you don't have any vacuum leaks ..don't worry about it.
| All times are GMT -7. The time now is 04:10 AM. |
