issue with my duster, i want to start it
First off its a 550hp 408 stroker engine 13.1 compression:mad:. I remotely mount battery in truck with 2gauge wire. after putting this new engine in, it will barely turn over. So I went out and bought a battery that has 980ca. Still doing the same this. wtf. Do I need to run dual batterys? do I have a bad ground? I am using a mopar performance high torque mini starter. Could this be a timing issue? If so any one have a link of how to wire in a mopar performance (6al) to factory? I also need to know the Proper way to drop in distributor and the distributor firing order. Its a 70-84ish block. I need help. Or I will pay for help. I'm in michigan
https://moparforums.com/forums/image...ser_online.gif https://moparforums.com/forums/image...ons/report.gif https://moparforums.com/forums/images/misc/progress.gif |
TRY moving the battery.... if it does not work UP-front .. it could be either bad wiring or a battery that is not up-to-snuff.
| All times are GMT -7. The time now is 04:21 AM. |
