Mopar Forums (/forums/)
-   -   key won't start (https://moparforums.com/forums/f7/key-wont-start-1685/)
tish Oct 23, 2008 05:55 PM
key won't start
wiring
I need a 70 roadrunner ignition switch wire diagram.
for some reason, it will not turn over
it's not the starter! it turns over when i hit the relay
it's not the relay! it does even click
so don't even ask!
i don't know if it's in the switch, or if I have a loose wire? I was searching for the reverse light wire and after moving things around, no start
Please if anyone can supply a wire diagram, so I know what wires are what on the switch
thanks
Tish
https://moparforums.com/forums/image...ser_online.gif https://moparforums.com/forums/image...ons/report.gif https://moparforums.com/forums/images/misc/progress.gif
tish Oct 23, 2008 07:29 PM
70 roadrunner.
I don't think it's the relay, I put a new one in but it doesn't click
something is not right, everything else has power
I checked the switch with a tester in start postition
brown-blue and black wires make contact with yellow
would like to know which wires the current follows through it's path to the starter, if anyone knows what to test
tish Oct 23, 2008 07:36 PM
are there wires that I can pypass, to narrow down what could be the problem?
anybody?
challenger Oct 23, 2008 09:00 PM
did you by chance knock off the neutral safety switch wire
tish Oct 23, 2008 09:28 PM
Challenger
thanks for responding, I managed to find the problem, when hooking up the back up light, I reversed the wires at the relay where these back up wires also are connected. I ran some power into my old relay and it clicked and then it dwaned on me to try and switch those two wires and that was the problem. after a few nights on my back with a flash light trying to see if there was a loose wire under the dash, here it was a simple fix
thanks
challenger Oct 23, 2008 09:31 PM
Kewl at least you got it hope everything works out http://www.moparnuts.com/forums/imag.../punkrocka.gif
rr69half6bbl Oct 24, 2008 06:51 PM
its agrivating isnt it? Mopars run like heck, but the wiring sucks.I always put new harnesses on all my cars when i get them anymore, its worth the money not to have the headache of braking down, Ive seen some nightmares too. i got 1 car in to work on for a guy ounce, they ran a hot lead off the fuse block out the bulk head to the coil to get the motor running.And the insulation on it was melted and scraped and was grounding out on the firewall.
