Mopar Forums (/forums/)
-   -   main cap bearings (https://moparforums.com/forums/f7/main-cap-bearings-3048/)
pjmopar May 14, 2009 06:13 PM
main cap bearings
Need a little help.My soninlaw is changing the rod bearings in his 2002 intrepid 3.5 engine,He is haveing a real hard time getting the main bearing caps off to check them.any ideal why this is happening .I live about 3 hours away from them so im hopeing for some info .I cant just pop over there and help him .
Thanks for any help
Paul
78D200 May 14, 2009 07:25 PM
Can he just not get them off after taking the bolt out or can he not get the bolts out at all?
pjmopar May 15, 2009 10:45 AM
Yes the bolts are out but he cant get the caps off.dont know whats going on ,but im to far away to help him.
Thanks
scotts74birds May 15, 2009 11:10 AM
I would think that a whack with a dead blow hammer or a piece of wood should do it. But put the bolts back in loosely so the cap doesn't go flying! And DO NOT FORGET TO MARK THEM TO PUT BACK IN THE SAME PLACE!
pjmopar May 15, 2009 11:16 AM
Thnk you Scott i will pass the info along
78D200 May 15, 2009 01:48 PM
And in the same direction.
