Mobile Home 413
Old Jun 19, 2009 | 10:48 PM
xynicgreven's Avatar
Junior Member
Mobile Home 413
So I bought a 413 engine/Tranny combo from a guy. What am I going to have to get to get it into the 74 Charger.
I picked up a couple Mopar Mags, and there a section about engine mount adapters in one of them. What Adapter am I going to need to get the engine to mount in correctly?
Also, will I be able to use the Tail Shaft off of the SB Tranny on the BB tranny? or am I going to be running into breakage issues?
Old Jun 19, 2009 | 11:36 PM
theomahamoparguy's Avatar
I think all that you will need is the correct motor mounts.
The chargers are B body cars and they used the same K frame for the bigblocks as they did for the smallblocks. You will probably need to get them from Shumacher be cause the insert will be easy to find but the mount itself is not sold at any large auto parts chains [auto zone etc], they just sell the rubber inserts that wear out for the mounts. You may be able to find them at a junk yard [look for any B body from 73-78 with a bigblock] A Chrysler Cordoba with a 400 would be one popular example.
The motor mounts would be the original application for a 400/440 equipped charger.{or any other B-body of that year} [ spool type ] If you have the 727 trans, you can use the tail shaft but I bet you have the 904 since it is shorter.
Sorry, you will need to use the tail shaft that is from a 727 trans [goes along with the bigblock] which most likely is the long shaft. You will need to get the correct length driveshaft or have yours shortened. Hope all this helps....ENJOY!!!
Old Jun 20, 2009 | 12:41 AM
Junior Member
amusingly enough. When I purchased the car, the guy gave me the long shafted Transmission.
I dont think, however I included enough information. The engine/transmission combo came out of an RV. The engine mounts dont look at all the same. I can take pictures and put them up here if that would help.
Old Jun 20, 2009 | 01:18 AM
What year is this 413? Hopefully it is not the industrial version with the weird heads. If it is the 'regular version' it should work. (block must have 'ears' on its sides for the motor mounts)
You are correct, the RV mounts wont work, that is why you must find the mounts from the example (Cordoba with bigblock). They will take the place of the mounts you have now {if you can find them} You can also get them from Shumacher Creative Services {on the net} brand new. {probably the better deal as they have the new style of rubber already installed}
By the way, hold on to that transmission and use it. The motor home transmissions are stronger than the car transmissions.
All that is required is to get the driveshaft shortened
Old Jul 16, 2009 | 01:55 AM
Junior Member
Okays. I've sourced the RB engine mounts that will bolt into my car.
Now to get working on the performance aspect of the engine. Any idea's on where to go for a rebuild kit?
What are my options for the heads? ( any chance I could put a wedge style head on it? )
Engine is out of a 73 Winne
Old Jul 22, 2009 | 02:50 PM
Morrigan_Aria's Avatar
Hell kitten
OKay, I have a question...
I was recently presented with an option to buy a '65 413 4 bbl and mated auto trans out of a 65 Chrysler 300. 59K original miles, runs good and the guy is an old mechanic and vouches for condition of motor/trans.
He wants what I feel is a very fair price for the combo.
The big question here is this: Is this worth putting into my 67 Belvedere? I considered building a big block this winter anyway. I was thinking a mild-tear down and gasket kit, send the heads off for hardened seats.
I already have the small block K member. The car needs a front end kit, and sway bars anyway. Due for a disk brake swap upfront anyway too.
Thoughts?
Old Jul 23, 2009 | 03:58 PM
why would you have the seats converted?
Old Jul 23, 2009 | 10:36 PM
Hell kitten
Pre-65 would not have hardened valve seats since they ran leaded gas back then.
Moot point, as I veiwed the motor today and it is not only NOT a 65 300L motor with weird cable linkage on the 727...it's also out of a motorhome. I'm in same boat as xynicgreven.
Anyone know the performance factors of this motor/trans?
Old Jul 24, 2009 | 05:29 PM
but the heads can still go tens of thousands of miles even without the lead
Old Jul 24, 2009 | 07:47 PM
Hell kitten
hhmmmmmm something to consider then....I think I am damn lucky woman...friend of a friend of a friend put me in contact with yet another hoarder today...
and he likes me.
THIS man has three 413's sitting in two 63 and a 64; all 300 and Imperials. I'm going to miss most of a day off work, he promised it's worth it to wander the acreage of cars he's hoarded over the years. I'll see what he's willing to part with and let you guys know. He's been "collecting" since the 50's. Also has a bunch of Dodge Army trucks and jeeps; he's starting to sell a few off.
Old Jul 25, 2009 | 09:22 AM
i wish i lived near you
lol
Old Jul 25, 2009 | 01:45 PM
Hell kitten
I wish you lived closer too, so I could look at your damn bumpers!!
Old Jul 25, 2009 | 04:28 PM
i think i have a good pic of them
lemme look
Old Jul 25, 2009 | 04:32 PM
sorry, i dont have a pic in my computer
i'll try to take one later
you need front or back?
Old Jul 26, 2009 | 02:41 PM
Hell kitten
Both! Or maybe you can see my car's bumpers in my pics? I'll have to look. I'm concerned that the previous owner just put random stuff on this car. Ugh. Trying to do what I can. Thanks!
Old Jul 28, 2009 | 05:42 PM
craveman's Avatar
Senior Member
you can buy lead additive for the fuel so your seats wont get hurt.
mopsled
May 11, 2023 06:00 PM
tesla57
Jun 23, 2010 08:10 AM
xynicgreven
Jun 19, 2009 10:27 PM
rr69half6bbl
Oct 29, 2008 06:52 PM
jane1043
May 11, 2008 10:37 PM
