Mopar ignition system/module issues
Hi guy, having a nightmare with the ignition system in my 67 Newport with a 383, I have so far gone thru 3 ignition boxes and am stumpped as to what’s going on, I have tried multiple coils and have a new ballast resistor and are still having major headaches, won’t start now again after fitting a new module yesterday. Any help or advice on how to test would be great, I’m in New Zealand and are struggling to find anyone that knows the system here |
Got it wire correctly?
Make the ground is good from the box to the body. ( I like to be safe and add a extra wire from the box mounting bolt to the Engine bolt on back of the cylinder block. Make sure all the grounds are good? (Engine to Body, And Body to Frame) https://www.forbbodiesonly.com/mopar...ng-jpg.460127/ |
