Mopar Forums (/forums/)
-   -   motor info (https://moparforums.com/forums/f7/motor-info-3044/)
panda! May 14, 2009 01:59 PM
motor info
hey everyone, ive searched this forums for some info but have come up short. my 68 coronet has a 360 in it. unfortunatley, since this was not a stock motor i need help in finding out where this 360 came from. are there numbers on the motor anywhere that could tell me where what kind of 360 it is? thanks gurus
78D200 May 14, 2009 03:21 PM
360s are pretty much 360s. They did change some over the years getting more HP and then losing some. If you can get us the casting numbers off of it we can help you out. Also there are 2 or 3 clock looking casting, that may help us out too.
panda! May 14, 2009 03:45 PM
the last sentence, what do you mean? and thanks for replying. your my hero;) hahahaha
Polaradude May 14, 2009 04:14 PM
The clock looking things denote day shift night shift and time of day, but as Tim said get the numbers off the block and we can tell ya a few things.
hypermite May 14, 2009 04:31 PM
I believe there is a V.I.N stamped into the pan rail near the bottom of the engine. (Good luck finding it !) post this number for us & we can tell you what year, make & model the 360 came out of. But like 78D200 said, they are all pretty much the same, unless you totally lucked out & got a police pursuit 360 !
panda! May 14, 2009 05:11 PM
lol......is having a police pursuit 360 lucky?? or are you being sarcastic (nervous laugh)
78D200 May 14, 2009 06:44 PM
I would call it equal to having a 340 with an upgrade or two. police cars always got the best stuff, especially when it comes to motors.
hypermite May 15, 2009 09:16 PM
Double roller timing chain, windage tray, heavy duty water pump,alternator, deep groove pulleys,four barrel carb. power steering cooler, etc.
67 GTX May 16, 2009 01:51 PM
did you find the numbers?
panda! May 16, 2009 05:57 PM
i could not find any numbers!! the only numbers i found are "392" on the oil pan.
also, on the front of the block i found somthing that said "before after" with o's or 0's underneath it, and on the side under the 1st plug theres a "21" WTF
Polaradude May 17, 2009 03:17 AM
Check the boss above the water pump and check the block drivers side about halfway/middle just above the oil pan rail.
panda! May 26, 2009 11:52 PM
head casting number 4027569
Polaradude May 27, 2009 03:27 AM
They are 360 heads that were produced from 77-86 They are 1.88/1.60
panda! May 27, 2009 12:21 PM
thanks for the info dude
Polaradude May 27, 2009 02:02 PM
No probs, did ya find the block #'s, get them and I'll decode that for ya.
