Need help finding bellhousing
Old Jan 6, 2021 | 07:17 PM
muscle truck's Avatar
Im building a pickup with LA 360. I have a A833 4 speed and i bought an 11" flywheel and clutch. I installed the flywheel and clutch and tried to install one of the 3 aluminum bell housings I have and the one that is closest to fitting hits the teeth on the flywheel. I had originally bough the 10" flywheel but I found out the clutch I bought the year before was for an 11 inch flywheel so I bought new flywheel instead of buying a smaller clutch. Than the bell housing didnt fit. now before I start throwing money out the wndow again, i'm asking first. Can anyone help?
Old Jan 7, 2021 | 06:59 AM
Welcome. I went through this and it is a pain. Most smallblock truck 11" flywheel bellhousings are for NP transmissions, they have grooves inside on each side for the teeth, I fabricated adapter mounts to accept the A833 which was a pain but worked.
I would strongly recommend buying the 10 1/2" clutch.
Dustertwister
Sep 19, 2016 11:22 AM
Mr.4spd
Mar 8, 2013 08:25 PM
lifted150
Sep 29, 2012 05:27 PM
69charger71duster
Mar 3, 2012 12:00 PM
70RT383
Aug 29, 2011 06:31 AM
