rear main seal
Old Mar 27, 2024 | 08:44 PM
fishy's Avatar
rear main seal
HI I am replacing the rear main seal in a 62 slant six.
Hoping to get help here.
Old Mar 28, 2024 | 12:30 AM
Welcome to the forum,
do you have the engine in or out of the car?
Old Mar 28, 2024 | 02:47 PM
fishy's Avatar
Engine is out,still has original rope seal.I have a new Fel-pro seal kit to fit,but how do i remove the old seal from the block and clean the seal grove?
Old Mar 28, 2024 | 04:40 PM
Kuvasz101's Avatar
You need to pop off the rear main crankshaft cap. After that, you'll be able to remove the rope seal from the cap (2 piece seal) and then push the other half of the seal outwards. They make a tool to push the seal out from under the crankshaft, but I think you'll be able to grab it with a point pliers and yank it out.
Old Mar 28, 2024 | 11:48 PM
I’ve always loosened all the main caps so I could lift the crank slightly then remove and install the new seal. I don’t put the lower seal in flush with the pan rail but off a quarter inch or so, this will help with sealing the two pieces together. Black RTV applied to the ends is necessary also.
Old Mar 29, 2024 | 06:01 AM
Kuvasz101's Avatar
Very good advice on loosening the main caps, thousands of an inch space will help out tremendously.
Old Mar 29, 2024 | 05:09 PM
fishy's Avatar
Thank you guys for your valuable advice.
Never worked on a Mopar before,mainly Mack trucks lol.
usedknobby
Jun 2, 2014 01:38 PM
raycan2
Nov 7, 2013 03:36 AM
fastdakota84
Jul 26, 2010 02:46 PM
DandyD
Apr 19, 2010 02:48 PM
SPICOLIE203
Aug 28, 2009 07:23 AM
