rear wheel and tire combo
Guest
Posts: n/a
i've been trying to figure out how wide of tire i can stuff inside the rear of a 66 coronet 500. there isn't a whole bunch of room and tubbing and spring relocation is out of the question. how wide of a tire and how wide of a wheel and what kind of back spacing would i need? any ideas on this from somebody that has done it? thanks
Guest
Posts: n/a
there isn't much room on either side for bigger tires. basically i wanted to know if a 245 tire would fit in there with a wheel with the correct back spacing. the thing with wheels and tires if you buy it and try to mount them you own them and can't return them. i was just thinking it would be much easier for someone who has a coronet who has done this would let me know so i didn't have to figure it all out. i have a ton of stuff to do on this car and it would be just one less thing to think about.
Guest
Posts: n/a
A 245 tire will fit- I have P245-60R14's on the back of mine, mounted on 14x8 Magnum 500's. Not sure what wheels you plan to use. I don't know the backspacing specs on mine- they were on the car when I got it; could probably find out, since they're pretty much a standard wheel. Hope this helps.
Guest
Posts: n/a
wheels and tires
with the 245 tire does it pretty well fill up the wheelwell with not much room to spare or is there room for an even wider tire? i think the magnum 500 wheels have quite a bit of backspacing to them similar to a plain oem steel wheel. i have 9 inch wide wheels with 4 inch backspacing that i wanted to put on the car but maybe they're too wide with not enough back spacing. thanks.
Guest
Posts: n/a
tires
hey there. if you seen the amount of room available you would know that this vehicle wouldn't take a really wide tire. the wheel arch in the rear is pretty well even with the top of the rim. i could do a mini tub on it but i don't want to get into cutting the car up. if i can get a 245 in there i think i'll be happy.
Guest
Posts: n/a
don't know what fits on a coronet, but agree a 60 series tire easily fits on a volare- mine has 60's on stock 14 inch magnum 500's, stock springs with no relocation, adjustable rear spring shackle, 8 3/4 rear. hot rod or car craft recently ran an article on fitting different tire and wheel combinations on muscle cars- it was a generic article with info for everyone ( even us- mopars). anyone remember what issue this was? think i might have recycled mine. mopar action has done a couple of articles on bigger tires and wheels- they have an online magazine. have you read any of their project bold beeper installments? i ask because they put some pretty big tires under their roadrunner, which is a b body like your coronet, right? when you find what fits, post it.
dodge_dart69
Mar 25, 2014 12:57 PM
