Running good gas still have cheap gas sound
When you run crappy arco regular and go up a hill or something you get that valve clickey sound
My 67 318 does this even with chevron premo
No sound during normal acceleration
Why?
Why?
Foe -
That "cheap gas sound" is called detonation and due to insufficient octane in the gas to prevent premature or uncontrolled ignition. Most 318s, unless heavily modified don't have enough compression to cause detonation, unless something else is going on.
Are you sure you know what you're hearing? Some times lifter tapping or even an exhaust leak can fool you. You can try retarding the timing (more than expected) to see if the sound goes away.
Several things, here
"Burning oil" (and it doesn't take much) causes detonation. Look, when you rev the engine, and have someone else watch, when you accelerate hard or let off does it smoke?
An engine that is overheating will detonate, as can one that is severely loaded up with carbon.
Timing. Harmonic balancers are two piece with rubber in between and CAN slip and move. It would be wise to check your timing mark, not all that difficult.
Buy or build a piston stop, like this:
Saw off the crimp on a plug, drive out the guts, and tap for a bolt. Adjust as needed.
Unhook the battery ground for safety, and get a socket on the front bolt. Check with a soft brass/ plastic probe that no1 piston is "down a ways" and then install the stop
Gently rotate the engine until it stops against the piston stop. You may have to play with the length. You do NOT want the piston to stop terribly near the top, but rather down some
With the engine now rotated and stopped against the tool, make a temporary mark on the balancer directly below the TDC mark on the timing pointer/ tab
Now rotate the engine the opposite direction (CCW) until it stops once more. Again, make a mark on the balancer right under TDC
Now, you'll have two temporary marks on the balancer. TRUE TDC will be exactly halfway in between the two, and if your original mark is correct, that is where it will be.
Now you can check your timing with confidence.
Alrigt thanks im gonna tweak my timing today to see if thats all it is
I recently put new gaskets on the exhaust but didnt use thee rtv on the bolts could that cause an oil leak where detonation could result
I checked my timing it was right on with the vac advance unhooked but not plugged, i plugged it and it advanced a bit so got it set and it seems like that was it.
Im confused though, ive been adjusting my idle mix on my edelbrock, in order to get around the 50 whatever suction units it has to be idling higher than i think is normal
When i set the idle speed shoul it be in gear or neutral?
The "old guys before smog" way of setting idle mixture was in neutral, at normal idle speed AND FULLY WARMED UP, adjust idle screw(s) until highest vacuum reading or highest idle rpm, then just touch the screw TOWARDS lean
Newer "smog" cars have differing procedures, some said same as above, then lean until gas analyzer said "so and so" and there have been certain propane involved procedures.
There used to be specified idle in neutral and in gear, MOST IMPORTANT is "in gear" because you don't want it to die, nor do you want to have to REALLY drag the brake all the time. Hotter cam, built engine, etc, makes this task more difficult.
You should put sealant on the front and rear bolts as they go into the water passage, all others are blind holes.
ahrkar
09-18-2012 10:27 AM
sebring28
11-06-2011 03:52 AM
northcoasttip
10-13-2011 03:22 AM
MrMiHoGiE
08-25-2011 07:58 AM
whbballer48
01-01-2009 07:54 AM
