Speedo Gear Question
Since my speedo doesnt work because there is no drive in the transmission, which one do I need?
Tire size : 235/75 R 15 Rear 3.23 |
Is this for the 65 Belv?
Yes it is.
im pretty sure you can buy the kit and it will have different color gears in the kit , i cant remember off hand how to config: it but there is a way and ill look into it for you just give me a day or so
OK. Thanks challenger.
I'd like to get that speedo working so I can take it on the street again. Using a GPS for a speedo in the land of speed cameras is not fun. |
hey a GPS is more accurate then a speedom but i understand and im still getting it together for u .... at least im trying but ive ran into some of my own delemas for the moment but will get back to you asap
forgot to ask, what trans is in your car thanks
I've got a 904 from a 78 Magnum.
hey 65Azbel the beast i can come up with is a 33 tooth gear which is a yellow one... do you have an email address you can give me and ill send you a chart and then you can also go from there ok :)
the part # is 2538933 for a standard style pinion gearing |
Here is the complete answer. Save this chart so you have it in the event of a rear gear swap or tire size change.
http://www.yearone.com/yodnn/tech/Te...5/Default.aspx |
Thanks for that site.
Looks like I need a 29/30. But what is the difference between the A and B style of speedometer drive? |
I went over to TCI auto/ transmissions, and they have both the 30 and 33 for 14 each.
The only thing I need to know now is: What is the # of teeth that drive the speedometer gear. |
open the hole and jack the car up then take a red marker, mark a tooth and turn shaft and count the teeth, its the easiest way i know :D
have you made headway on the speedo :)
do 904 & 727 use the same speedo drives ?
also a little tip, when installing - on the housing there are markers for how many teeth on the gear you are using - line the appropriate one with the marker on the tranny itself.
| All times are GMT -7. The time now is 12:29 AM. |
