speedometer not working??
Old Aug 8, 2010 | 08:35 PM
ctrain22's Avatar
I have a 67 Sport Fury. My speedometer pins the needle all the way to the right when driving. It will stay once it gets there even when I stop. I can disconnect the cable, turn the thing the cable goes into and bring the needle back to zero. But when I hook it back up and drive, at first it will bounce, then go straight to pinned to the right. Any ideas what to do????
Old Aug 8, 2010 | 10:03 PM
1966sportfury's Avatar
A.K.A Bob Dodge
cable frayed? making it bounce? the replacement cable cut to fit style is pretty cheap 8 bucks or so, id 1st check and see if the cable itself is bad,
Old Aug 9, 2010 | 03:40 PM
could it be the spring inside the speedometer?
Old Aug 9, 2010 | 06:19 PM
jdewoskin's Avatar
I would pull the speedo housing from the tranmission and check the condition of the gear. On the 727 you can rotate the housing in the transmission to adjust the gear clearance. Perhaps it's out of adjustment and it's jamming the gear.
Jake
durangogirl
Dec 11, 2012 09:25 AM
Mixmastermerrill
Aug 27, 2008 03:28 AM
gilesie
Jul 14, 2008 02:29 AM
azzkikr
Feb 21, 2008 04:36 PM
Plyduster318
Sep 22, 2007 05:32 PM
