switching to electric pump
Old 07-28-2009 | 03:33 PM
craveman's Avatar
Senior Member
im thinking of switching to an electric pump on my 85 fifth ave with the 318 in it. just wondering what you guys would recommend for a new pump and how to set it up. my car has a 750cfm qjet on it if that makes a difference.
Old 07-28-2009 | 04:07 PM
scotts74birds's Avatar
Why? I doubt fuel delivery is an issue. 750cfm? I hope its a vac secondary, still maybe too big.
Old 07-28-2009 | 05:07 PM
Crazy4Carz.Com's Avatar
Why an electric pump? there are so many things that go with that (noise, regulator, return lines) and why such a big carb? your 318 would respond well to a 600.
Old 07-28-2009 | 05:35 PM
craveman's Avatar
Senior Member
qjets had a max output of 750. its got small primaries in it and gives me great torque and top end when i need it. vac secondary air valves only let in as much as it needs. actually runs better than a 600 performer did till it was stolen. runs great when its cool or going short distances i never had a problem. when it gets hot it seems like the fuel is cutting out. my mechanic also beleives its a fuel temp problem. not worried about the noise of an electric pump. headers with duals exiting in front of the tires drowns out all other noise.
Old 07-28-2009 | 05:37 PM
craveman's Avatar
Senior Member
with an eddy performer i ran 17.20 @ 87mph and the qjet ran 16.53@89 mph my 0-60 with the qjet is around 8.6 seconds so i believe the carb is just right for the engine.
Old 07-28-2009 | 07:12 PM
theomahamoparguy's Avatar
no, the problem is what alot of people are having problems with latley, vapor lock due to the poor quality gas (theres alcohol in it or oxygenators). I agree with the idea of runnung the electric fuel pump. Find one that has about 14 -15 psi. (there out there) and then regulate it down to 5-7. The less fuel pressure you can get by with the better with the Q-jet (i know lots about Q-jets). also, go out and get a feul filter with a bypass line.(two big lines and one little). run the bypass line back to the tank [you may already have this on your fifth ave]. Also, reroute the fuel line away from any heat source, maybe place the filter inline with some airflow from the fan. Insulation wouldnt hurt either.
The Q-jet is a great carb when set up right and came on 318's from the factory in the eighties so I dont think it is too big.
Old 08-02-2009 | 07:27 AM
craveman's Avatar
Senior Member
i ran a transmission cooler behind the grill for a fuel line cooler and it seems to be working quite well. still may upgrade to an electric pump though. thanks for the help
Old 07-05-2011 | 07:16 AM
joeygreaser69's Avatar
WTF
"damn hippies you want organic then eat a damn squirrel and shut your face."
What the hell does that have to do with anything?
Keep eating your pesticides then.
Old 07-05-2011 | 08:51 AM
An electric pump will not NECESSARILY cure vapor lock and related problems
Does your vehicle (not familiar with 5th av) have a fuel "vapor return" system?
If not, PUT ONE in there. Wix makes two filters, a 5/16 and 3/8 inline, metal throwaway, which has a third 1/4 return orifice. The 3/8 is 33041, not sure of the 5/16
You can mount them either vertically or horizontally so long as the 1/4" return is on the "up" side
They look like this:
gunnerman
04-30-2021 06:05 PM
D.j. Kellogg
19
03-10-2013 04:17 AM
440-4x4
08-14-2011 04:46 PM
tazdevilish1
02-05-2011 03:17 PM
Henrius
11-13-2009 12:36 AM
Quick Reply: switching to electric pump
