Thermostat replacement for 2019 Ram with 5.7
Looking for advice on which temp thermostat to install on a 2019 RAM with 5.7L engine. I was told that OEM is 203 degrees, but there are other choices that run cooler. Should I stick to the OEM spec one or install one that runs below 200 degrees?
Thanks in advance for your responses. |
I would recommend staying with the OEM temp.... Some of your sensors work better at those temps... The Computer knows what its looking for....
Cheers. |
| All times are GMT -7. The time now is 11:55 PM. |
